Old 08-11-2010, 04:50 AM   #2 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by miket View Post
The inside panel/strip between every other flute would be trimmed out. That would make the sheets very bendable
Wouldn't that also seriously reduce the Coroplast's strength ?
After all it's the box structure that gives it that strength - remove the box and you likely end up with ordinary floppy plastic sheet.
