Old 08-11-2010, 05:55 AM   #8 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by euromodder View Post
The 1.6D has a 5 speed box.
I'm almost sure that you have same engine that I do: DV6TED, a 1.6 commonrail turbodiesel, designed jointly by PSA and Ford, found in all sorts of cars like Citroen/Peugeot (1.6HDi), Ford (1.6TDCi), Volvo, Subaru, etc. Mine is also 2005, so should I also be expecting a leaky injector?
Officially, it's 1375kg / 3031 lbs, including a "standard" driver (75 kg/165 lbs) and 90% fuel, but I plan to have it weighed.
Svietlana officially weighs 1466kg, but I checked that it's actually less, only 1300kg without the rear seats.
Taking into account that we both have the same engine (and probably transmission) and that your Volvo is not as tall as mine (smaller frontal area), has a lower drag coefficient (0.32 compared to my 0.334) and is slightly lighter, plus LRR tires, I'm amazed that your fuel consumption is so high My car should average 5.6 l/100km, over 10% more than your's, so I think it's the diesel particulate filter that's killing you. Is it the PSA's FAP filter, or does Volvo have its own, different model of filter (do you have to add a liquid called Eloys at the service station every so often?)?
Those filters are wicked! Not only do they cause problem codes all the time, but they also require a high exhaust temperature to burn out every 500km or 1000km, so unless you are chased by the police very often, the engine's computer will add more fuel when the burn process is in need to raise the exhaust temp. This causes your fc to go through the roof. And the best part about it is that you won't find anything about it in the official numbers, since the fc testing is done with a car with a clean filter, not by a car in need of a burn out. Wicked wicked wicked!!!
I don't know exactly by how much the dpf improves emissions, especially after 3-8 years of use, but I wonder if it is worth the extra fuel burned (not taken into account when calculating fc and emissions), or the loads of $$$ spent at the service station clearing codes, adding Eloys, or regenerating the filter. Many Peugeot and Citroen owners have dealt with the problem by removing their FAP and adding a sensor emulator to trick the computer. Many of them do it thinking they'll get better performance numbers, others because of all the trouble the FAP has caused. Unfortunately, emissions aren't checked here as regularly as they should be, so I have no idea how this is effected by FAP removal.
I am by no means suggesting you should remove your filter!! It may, or may not, be better to keep it, I don't know.
