I hear you on the radius, light was dimming so I did what I could. I now have a rough size to try to get chloroplast for. I think that I can make it rather rounded. How well does chloroplast bend into radii? Should I use heat?
To attach the bottom I will borrow from Piwoslaw and use clips. I will run them from the back/ side brace under the glass (where the hatch and glass open independently) and then up to the shock mounts.
My idea is to make removable with very little work (and put the old piece back on). It will make for better testing and if I do not like it I can take it off in a min or two.
