Old 08-13-2010, 02:03 PM   #565 (permalink)
schlorkist
Originally Posted by Froggy View Post
Can I use the .1uf 25v instead of .1uf 16v without damaging anything? Or should I stick to the specs.
Sure, 25v is more than 16v, so it will be even more robust.
Regarding SMD soldering - no problem, just use serious tweezers and rest your palm on the workbench to reduce shake. Handsoldering even 0402 capacitors is a joy if you have fine tweezers and an appropriately sized soldering tip.
