Originally Posted by cons
This guy claims you can generally save around 6% of gas by not having your lights on.
Though there will be a minor power drain from using the headlights, I've never noticed any perceptible difference in FE with or without having my headlights on (either as DRL of as normal lights).
I had Volvo's always-on set-up changed to be able to switch the headlights off, but not because of FE reasons
If true, I think using LED lights
Nothing else should really be used for DRL.
LEDs draw a lot less power, and being smaller they're sufficiently different from regular headlights to minimize the risk of other road users being rendered nearly invisible near cars with them on.
Originally Posted by alvaro84
I can't turn Teresa's low-beam light off (constant 55W load) - because of regulations the light just doesn't have a switch (AFAIK lighting on motorcycles is compulsory in Europe, every time) - but I think I normally would seldom turn it off anyway. According to my experience I'm practically invisible without it ![Frown](/forum/images/smilies/frown.gif)
AFAIK only in the UK it's not mandatory to have your headlight on on a m/c .
Don't turn it off for FE reasons on a m/c.
It's bad enough with the headlight on, no need to make it even more dangerous.
If it's allowed where you live, try out a yellow light.
