Old 08-16-2010, 10:09 AM   #33 (permalink)
Tweety
Out of my mind, back in 5
Originally Posted by euromodder View Post
With less teeth the sprocket diameter gets smaller, so the chain tapers more toward the front, and the gap that the swingarm sits in gets narrower.
If that's the sort of ratio you want, I'd use the larger sprockets.
Also, if you reduce the front sprocket, you increase wear on the chain...
Tighter bend, higher torque load on a smaller area/less links... And more overlap on the teeth count over the rotation... Go with the 14 front...
