Old 08-18-2010, 10:33 AM   #14 (permalink)
saand
Wiki Writer
bugler - '91 Mazda 626
90 day: 35.89 mpg (US)
So after a bit of learning how to write wiki pages I have made up the template and I have entered some data in for one of the mods the "side mirror delete" which is one that I know weather spotter has some data for. I have also done this mod so I put in my "unproven" information as a starter.
I have essentially copied the bulk of the data from the 65+ mod list web page (hope nobody minds) and added a few lines from my own experience.
I already realized we need a difficulty indication in the template so I am sure this will all evolve when more people use the pages.
Weather spotter I leave you to modify this first page (side mirror delete) with your data. It is a little confusing to modify the pages to start with but hopefully with the template I have set up you can modify most things without looking up how to write a wiki page.
There is an example for new lines, different sections, images (note: you need to first upload an image before using it in a page), tables and links.
For anyone new to the wiki's if you find a wiki you want to change you need to log into ecomodder then go to the wiki (only registered users can edit wikis) then when you have navigated to the page at the top there is a tab with the text "edit" press that and you will be taken to the edit page with the source information which you can change as much as you like.
Before submitting a page change press preview first to make sure you have not completely messed things up. Also I kept getting automatically logged out so copy your work before submitting it so you don't loose it.
If you dont know how to do something there is a manual at the bottom of the main wiki page (the page linked to by the link in the title bar "wiki"). This manual is a little difficult to understand. I assume it is written by people that write code so they seem to assume the readers also understand code. So if anyone has questions feel free to PM me or ask questions in this thread.
