Old 08-18-2010, 01:41 PM   #2 (permalink)
Weather Spotter
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
It is there to keep the battery cooled. If it is mostly enclosed than most of the heat from charging or discharging is contained (not good) and can cause the battery to over heat. I would still let some air flow into that area (it will also help keep other under the hood electronics cool).
