Old 08-18-2010, 04:17 PM   #21 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
On North American VWs the headlights are Daytime Running Lights at 70% power. I disabled the DRLs and installed a "Euroswitch" which gives me parking or city lights (depending which side of the pond you are on). I used two yellow LED marker lights in the grill wired into a switched fuse tap for DRLs. I like the safety aspect of the yellow LED marker lights with minimal draw on the alternator. They should last the life of the car unlike the headlight bulbs you always see burned out on VWs in this country.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
