Nice work Tas. Have you thought about changing 5th gear to lower your rpm? Your Jetta looks pretty aerodynamic so you may not need as much power at highway speeds. I just completed a belly pan (new thread coming soon) and it seems to be helping. I have a very steep driveway so I can't really add air dams.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
