Old 08-19-2010, 10:50 PM   #10 (permalink)
Weather Spotter
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Last winter I had a full grill block but as the temps got warmer out (above about 40F) the fan was comming on all the time so I took them off. Now I see that I could have left the bottom one on. I remade the upper grill bolck though because I did not like the looks of the old one. It had the toytoa logo area cut out (which still lets air through) and I did not like the look. So I removed the logo (came right off with a screwdriver) and make a full block. I will be painting it to match my car (silver) which should also look better than the glosy black.
Did you see how much of the bottom one you could block all year as well?
I want to make the bottom one able to be opened/ closed from the drivers seat, how should I do this?
