Old 08-20-2010, 10:31 AM   #15 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Originally Posted by Automcdonough View Post
From the perspective of running at a loss to recharge at home I can see the benefit
And under those conditions, I have consistently seen a significant, measurable improvement in fuel consumption in real world driving (vs. that as-controlled-as-possible steady speed testing).
but outside of that it seems like you'd be putting yourself in a position to constantly fret about reliability in range and restarting.
AKA range anxiety. Once you understand how much energy is available, and learn to monitor consumption (voltage, simply), it can be managed.
I also drive an EV. I understand this. It doesn't cause me to fret.
I'll be the first to say disabling the alternator is a complicated and not particularly user-friendly mod. I don't usually recommend it to people who aren't willing to put in the effort required to reap the gains. It's definitely not a "set it and forget it" situation.
EDIT: Also, you need to do the math. If your goal is financial savings, it could be a wash, since you'll be burning through and replacing batteries at a faster rate. (I have a source of cheap/free used batteries - not an issue to me.)
