Old 08-20-2010, 03:11 PM   #38 (permalink)
jackbauer
jackbauer's Avatar
Started to do some intital setup now that i have motor number one back together and taperlock sprockets fitted. Also got a 5 metre length of "10B" roller chain and 5 clip links from challenge power transmission for less than 40 euros. Turns out its the exact same fit as 530 motorcycle chain. Before everyone starts screaming that its not safe or not rated for a bike , relax. Its just for setup so i can determine the link count for the final chain and get everything lined up without worrying about screwing up.
I've ordered a 6mm endmill rated for hard steel so hopefully milling out the keyway on motor number 2 will be less a tour de force than last time .......
ID:	6615   Click image for larger version
ID:	6616   Click image for larger version
ID:	6617   Click image for larger version
ID:	6618   Click image for larger version
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
