Old 04-11-2008, 02:13 AM   #14 (permalink)
Duffman
Why not use engine coolant? Tee into the heater hose at the water pump and throtle the flow with the same type of controls that you use on your existing heater. Water temp is much more stable than oil temp and would be easier to control I would think.
