Saturn SL2 service engine light rest help needed.
I'm working on a 1998 Saturn SL2 that has both a service engine light and a check engine light, the check engine light is what goes on when the ECU has a code stored, I hooked up my scan gauge and reset the codes and the check engine light is still off but the service engine light is on without any error codes so it would seem that it's a timed light to remind you to change your oil or whatever and I can only assume that there is a button or jumper or something to reset it and the rest of the internet is failing me in finding an answer.
