Old 08-24-2010, 06:09 PM   #91 (permalink)
ShadeTreeMech
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
I'd suggest a good hole saw instead of a drill.
Definitely use a hole saw vs a spade bit. A spade bit is likely to grab the material and spin it wildly out of control, or twist the drill from your grasp. Major bad idea! Even if it were to work, it could possibly induce some stress cracks around the edges which could haunt you later.
If you don't need super high precision use a small bit to cut several smaller holes along the tracing of the 1" hole till you can punch the hole out with a hammer, then clean it up with a round file. You'll still get a good looking hole, and it won't cost much. Make sure to keep your bit cool with lube; I've found even old motor oil or vegetable oil works great for keeping a bit cool.
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
