Old 08-24-2010, 06:09 PM   #91 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
I'd suggest a good hole saw instead of a drill.
Definitely use a hole saw vs a spade bit. A spade bit is likely to grab the material and spin it wildly out of control, or twist the drill from your grasp. Major bad idea! Even if it were to work, it could possibly induce some stress cracks around the edges which could haunt you later.
If you don't need super high precision use a small bit to cut several smaller holes along the tracing of the 1" hole till you can punch the hole out with a hammer, then clean it up with a round file. You'll still get a good looking hole, and it won't cost much. Make sure to keep your bit cool with lube; I've found even old motor oil or vegetable oil works great for keeping a bit cool.
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Old 08-25-2010, 06:24 PM   #92 (permalink)
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
Got a hole saw set, but tested with a spade bit, the hole saw worked but the spade was easier, honestly.
Anywho, started cutting, it's starting to come together! I still need to make some adjustments and cut for the bolts.
Honestly, if I had it to do over at this point I'd make the front bracket again, it's not pretty now but it does work.
Old 08-25-2010, 09:11 PM   #93 (permalink)
Basjoos Wannabe
I wouldn't have thought a spade bit would do the job.....
I would worry more about strength and less about beauty. higher mpgs are a beautiful thing as well!
Old 08-26-2010, 03:42 PM   #94 (permalink)
A madman
brucey's Avatar
Well, the motor fits in place, and I'm ready to start drilling for the mounting holes, but the hole I made for the shaft is just a bit too small. Now I'm having trouble enlarging the hole with the other hole saws. They wont stay center with the drill bit in a 1" hole. A drill press would also work. Anywho, with the motor in place, even without the brackets finished, it fully supports the weight and even under starting/revving the engine doesen't hit the frame or hood. Very good!
I realize most of the problems I've had would be easily solved with a complete workshop, but alas, I do what I can with what I got.
Happy to report though my idler pulley has shipped, and I'm in talks with a maker of custom pulleys to make one to fit my shaft. Once done, fabrication for the motor will be basically at 100%, then onto wiring and finally onto batteries and racks in the trunk.
Old 08-26-2010, 06:44 PM   #95 (permalink)
Dr. Jerryrigger's Avatar
The Sh*t-Box - '99 Subaru Impreza Outback Sport
90 day: 27.81 mpg (US)
Great job!
To open the hole up a little I would suggest a rat-tail file. Aluminum is surprisingly easy to work with.
Going at it with a larger spade bit will be a mess, as you won't have the pilot spike to keep it from slipping. Hole drills will have a similar problem.
An alternative is using a large twist drill (an end-mill would be much better) in a hand drill and try and cut the edges down with the side of the bit. This gives sloppy results, and is kind of dangerous, but could get the job done. Some twist drills are made better for this than others, so if you go this rout; try all the larger bits of different makes you have access to until you find something that works (but you should really just use a file).
This seem like one of those projects that would take 1/20 of the time with a milling machine and proper tooling. It's always more frustrating knowing that there is a better way, which you don't have access to, but such is life.
Redneck Repair forum
Old 08-26-2010, 07:32 PM   #96 (permalink)
A madman
brucey's Avatar
I took the plate and set it on a block of wood, with the drill bit driving into the wood it was simple to keep it centered. I started drilling some of the bolt holes for it and gathered up the bolts. I should have the motor in the car tomorrow. I also think I'm going to have to have someone weld me up a T brace to attach to my intake manifold. I can't bend the 2" X 1/4" steel by myself.
That's all for today!
Old 08-27-2010, 10:07 PM   #97 (permalink)
A madman
brucey's Avatar
Ah, nothing quite says "Business" like grade 8 bolts and primer paintjobs.
I now plan to do an additional support bracket, wrapping from the bottom of the flat bracket up and around to the intake manifold, basically 'belting' the motor in place. I do not like how much slack is in the lateral momentous (It can twist just by hand, but is otherwise in there tight) so I'm going to play it safe here.
Don't want my motor twisting itself apart and damaging itself, or my engine
But yeah, when my idler pulley arrives next week it should be the last time I have to work on that front one. Then just the stay brackets to triangulate it and fabrication should be done. I can also now get dimensions for my custom pulley made now, and hopefully will have that one soon!
Old 08-28-2010, 03:11 AM   #98 (permalink)
Basjoos Wannabe
kewl looking job!
Old 08-30-2010, 08:30 PM   #99 (permalink)
A madman
brucey's Avatar
Alright, got my specs on the custom pulley out today and hopefully that should be arriving soon.
Other than that, the idler pulley should be arriving tomorrow and I'll be installing it, which should be the last time I need to take the front bracket off.
Old 09-01-2010, 02:33 PM   #100 (permalink)
oh dear, metric and standard on the same print. I've spent the last few days dealing with the problems that can make... but it is necessary some times...
Edit:
Before you install the idler; think about the belt size! A measuring tape would be good to have handy, along with a model of your motor pulley (hunk of styrofoam?).
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
Electric assist for SUV? Tony Raine EcoModding Central 8 10-15-2012 08:17 PM
Electric sailboat motor: new conversion project (update: project shelved) MetroMPG Fossil Fuel Free 51 07-25-2012 10:21 AM
DIY hybrid (detailed noodling of crankshaft-mated electric assist method) NiHaoMike Hybrids 16 03-03-2012 05:41 PM
New CVT transmission electric-assist with electric assist Ptero Fossil Fuel Free 2 09-23-2010 10:41 PM
