Old 08-25-2010, 06:10 PM   #19 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
grillbritt -
Originally Posted by grillbritt View Post
Today i did some research on my job in our Scania workshop manual and it says that pin 1,4 is supply and 2,3 is CAN but it didn´t say which was which. tomorrow i probably going to look in the circuit diagram and found out which is which, but even if i know that i must communicate through a CANbus interface. i found one on this page lawicel-shop. se/shop/ search for LAWICEL CANUSB Adapter. But then you going to need software to understand the data from the nox sensor, probably you need to make an own program for this...
That's what I was afraid of. As mwebb said, it's a sensor designed for CAN systems. Maybe if you had a spec on the sensor itself, independent of what the smart circuit does, you could bypass the "smart" part. But I would not do that unless I knew everything, because I am implying cutting it up, and I think that VDO sensor is expensive, yes?
CarloSW2
American Solar Energy Society
