Old 08-26-2010, 03:42 PM   #94 (permalink)
brucey
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
Well, the motor fits in place, and I'm ready to start drilling for the mounting holes, but the hole I made for the shaft is just a bit too small. Now I'm having trouble enlarging the hole with the other hole saws. They wont stay center with the drill bit in a 1" hole. A drill press would also work. Anywho, with the motor in place, even without the brackets finished, it fully supports the weight and even under starting/revving the engine doesen't hit the frame or hood. Very good!
I realize most of the problems I've had would be easily solved with a complete workshop, but alas, I do what I can with what I got.
Happy to report though my idler pulley has shipped, and I'm in talks with a maker of custom pulleys to make one to fit my shaft. Once done, fabrication for the motor will be basically at 100%, then onto wiring and finally onto batteries and racks in the trunk.
