Old 08-27-2010, 04:48 AM   #57 (permalink)
mikeross
Originally Posted by pgmomni View Post
A couple of other members concur and today I may get around to tweaking.
Was thinking of making some side skirts too as I have more vinyl siding anyway.
I need to work on changing over to water injection as opposed to water induction. Induction method draws more water on high vacuum, less on low vacuum (high load, throttle opened wide) when the exact opposite is what is desired. Need to use washer fluid pump and a misting nozzle in the throttle body along with a vacuum switching valve the shuts it off under high vacuum.
A couple of times when idling in traffic it "sucked" down 8-10 oz of water dam quick when map was in low 4's. Good way to blow a head gasket or bend a piston rod or valve.
Pete
You're right at that Pete. That's what I hate about heavy traffic. I need to have enough water to make sure that it won't blow the gasket.
