Old 08-27-2010, 09:30 PM   #5 (permalink)
NachtRitter
NightKnight
NachtRitter's Avatar
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 54.39 mpg (US)
Mathilde - '99 Volkswagen Eurovan Camper
90 day: 16.87 mpg (US)
I do like the idea of a front wheel skirt that is not top-hinged but either mounted on some sort of a center pivot (fixed vertically) or mounted on the suspension (so that it moves vertically with the suspension).
Neil Blanchard has some thoughts about a front wheel skirt that's a little different in this thread (http://ecomodder.com/forum/showthrea...ter-11969.html). His idea is to hinge the skirt vertically so that only the part that needs to move out of the way for the tire is actually moved (for example, if the front of the tire needs to move the skirt out of the way, then only the front moves; the rear half of the skirt stays in place).
That approach should reduce the complexity compared to a pivot mechanism (which would have to be pretty well centered with the wheel rotation in order to avoid binding) while also not adding the unsprung weight that a suspension mounted system would add.
