Old 08-29-2010, 02:27 PM   #56 (permalink)
Patrick
Patrick's Avatar
Hot Tamale - '10 Toyota Prius III
If you have a welder, you could weld the rod clamp directly to the vent bar as shown in this pic. Then if you turn the vents around you should have a straight shot down with the rod from the actuator to the clamp. Turning the vents upside down should make the default the open position.
