Old 09-01-2010, 05:54 PM   #133 (permalink)
Civic-Man
Dear 88hf, i have P2J-003 (actually got two of them). but a said in my earlier post today, i saw a Ferio with 3 stage (CVT one) and came to realize that i am missing Purge selonide and canister container. is there a way to set this engine without them?
Also you said PDF!!! i guess you are referring to some repair manual, can you be a bit more specific which one. Today i had another heart attack. i received my scanner and also came to know that my car dont have 16 pin diagnostic connector. my car have a three pin diagnosis connector.
Guide plz now what are my options now, can i
Originally Posted by 88hf View Post
civic-man, that ecu is not correct. Do you have the correct one? vacuum lines should be indicated in the fuel and emissions pdf... probably the same whether 96 or 99 version but i'm not sure. As for the intake manifold it looks to be right. egr wiring should be shown in the wiring diagram pdf. You need to know which ecu you are using to tell how the stuff all goes together. I would guess you are using the P2J-003? If you aren't using the correct ecu I don't know how it could work properly or how to wire it.
