Old 09-02-2010, 10:07 PM   #123 (permalink)
Zerohour
Zerohour's Avatar
Pooparu - '01 Subaru Outback Limited
90 day: 28.12 mpg (US)
Cop Car - '94 Chevy Caprice Interceptor 9C1
Last 3: 18.48 mpg (US)
Mini - '11 Mini Cooper
90 day: 37.63 mpg (US)
Gramps - '95 Subaru Legacy Postal
90 day: 23.18 mpg (US)
I believe what you might be referring to is the a "gloss" resin. The type of coat that is used on wooden boats and paddles. Its a clear resin with a high gloss.
I use Bondo resin in the gallon containers. Occasionally I use the quarts. I never purchase the "repair kits". I'm not aware of any differences between the repair kit and the quarts/gallons. The gallons generally dry with a semi-tacky surface, which aids in bonded the next layer. If you use alot of hardener or have long dry time the surface does becomes dry/smooth to the touch. If the Bondo resin is a "finishing" resin that yes thats what I use.
