Old 09-05-2010, 05:05 PM   #140 (permalink)
shorty_boy
shorty_boy's Avatar
88HF,
There is a scanner wire on the ECU for a scan tool (C8 for obd2a). I don't know if the JDM scan codes are the same as the USDm or UKDM codes. You could always just use the cel trick for obd2 cars to flash the codes if that is the case.
I just finished tidying up the wires and converted the harness from rhd to lhd. Too bad my rex is my dd. i'm going on faith that I have wired it right. Let me know if there is a major difference between the vacuum hoses and the ones going to the box on the firewall (i forget what it is called right now.)
I don't know about the axles because my hf is still stock and I am going to reuse the HF trans.
1989 CRX HF "... and i will call her betsie and betsie will be mine!"
Resurrected 1/15/2012.
Shorty's Mods, Swaps, and Reviews.
