Originally Posted by cfg83
trikkonceptz -
Can you do me a favor and tell me what your RPM and MAP are when the car is off and the key is in the ON position? The reason I ask is that when my key is in the ON position, I still see 61 RPM. That leads me to believe that the SG thinks the engine is still running, however slightly. The 61 RPM could be an error in the sensor at 0 RPM (likely), or some kind of failsafe non-zero value reported by the ECU/PCM to avoid divide-by-zero errors (not likely, otherwise why not 1 RPM for that case).
CarloSW2
Will do, I will try it on my way home and I will post my results as soon as I can ...
