Old 04-13-2008, 02:02 PM   #261 (permalink)
bennelson
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
tore apart Nissan Forklift Motor
Greasy FUN! - Ok not really all that fun. Still pretty cold out right now to be covered with WD40 and using metal tools.
I finally was able to get the end off the big double-ended forklift motor.
It was INSANELY greasy/grimey/dirty inside.
I degunked it as best I could with my fingers and a palate knife. Then just hosed down all the parts with WD40. Should help degrease it and keep from surface rusting while it is apart.
Inside is four electro-magnetic coils and four matching brushes. The brushes are pretty beefy sized, but are VERY worn down and will definately going to need to be replaced.
When I first tested the motor on 12V - I could see a little bit of arcing off one of the brushes.
The commutator looks pretty worn. I think the brushes were so worn down that they were digging in funny. I think brushes are like brake pads - you just need to wear them in a little bit before everything fits really well, right?
The middle chunk of motor, which holds the field coils, is 7 inches long. (on the left in the photo on the top)
Now that I have it apart, I can see if somebody like Jim Husted will take a quick look and offer advice.
You can see more photos of this motor torn apart HERE
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
