Thread: M5OD or M5OD-R1
Old 09-09-2010, 10:18 PM   #3 (permalink)
Zerohour
Zerohour's Avatar
Pooparu - '01 Subaru Outback Limited
90 day: 28.12 mpg (US)
Cop Car - '94 Chevy Caprice Interceptor 9C1
Last 3: 18.48 mpg (US)
Mini - '11 Mini Cooper
90 day: 37.63 mpg (US)
Gramps - '95 Subaru Legacy Postal
90 day: 23.18 mpg (US)
T-5 where used in Mustangs, Cougars, and T-birds as well. (Also S-10's but those are different splines IIRC)
I'm not sure if they would still match up with the 97 Ranger. What year did they switch to the 2.3L Duratec in the Ranger? I would be surprised if a T5 would mate to that engine.
Back to the M5OD...those transmissions have been in Ford light duty trucks for a while. I'm sure the gear ratios are different depending on model/year/engine. Some quick digging on google and those babies have the bellhousing cast into the transmission case. So if the backside of your motor doesn't match, it pretty much will NEVER fit. But you'll have to look up more details on the motor you looking to use and the transmission you're looking to use.
Also don't suspect that you can just swap the gear either. The internals from year to year, especially with a ratio variation, may not be interchangeable. You would probably be better off having the entire trans swapped.
