Old 09-10-2010, 02:00 PM   #2 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
I assume this is for the Maxima? Will you extend the belly pan in the future? If so, you may only need the part of the airdam that is in front of the front tires. If the underbody is smooth you don't need to add all the frontal area of a complete airdam. Mock it up with tape and cardboard and test it with your ScanGauge to see which works best for you.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
