When I pulled the AC and power steering from my car, it took about 50 pounds off. Not sure how big a Tercel's AC compressor would be.
If your car had manual steering as an option, I suggest going to a junkyard and pulling a used steering rack to swap, then remove the power steering system entirely.
On the side of your tire, it'll show the max inflation pressure next to the max load. I'd inflate them to max, but not beyond. I run my tires at 50 PSI.
In Reason we Trust
