Old 09-16-2010, 11:16 AM   #126 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by 3-Wheeler View Post
To accomplish this, the plan is to "embed" such items into a cutout in the sloping sides of the extension, and cover the lenses with clear acrylic.
Jim.
I hope you can arrive at a simpler solution that meets safety requirements and doesn't ruin the lines of your beautiful work. I remember seeing a luxury SUV which has the reflectors as narrow strips in the rear bumper instead of integrated with the taillights. Could you possibly put simple reflectors into rear wheel fairings to indicate true width? If you feel they must be in the tail, you could use a small cutout "frenched" (hot rodder term- used for antennae mounts etc.) into the tail, the air would skip right over them.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
