Still praciticing fiberglassing...
Made out of coroplast base, then a layer of foam for flushing, then another coroplast top layer, then a layer of fiberglass, then a layer of bondo. But as you can see, the foam didnt quite stick to the coroplast, so it started warping after everything has cured.
![Mad](/forum/images/smilies/mad.gif)
Definately gonna have to do a v2.1 ditch the inner foam core and add additional layers of fiberglass for strength to prevent warping again. Still debating on whether to start fresh or continue to modify what i have now.
While I had the bumper off, I added a partial front belly pan and a wheel spat. But I may end up removing the spat since my car is already lowered, that spat just rubs on EVERYTHING.
![](http://i101.photobucket.com/albums/m65/jedikn1te/car/3d6d5b9b.jpg)
