Old 09-20-2010, 07:36 PM   #13 (permalink)
saand
Wiki Writer
bugler - '91 Mazda 626
90 day: 35.89 mpg (US)
creeper, i would love to be able to tune the ECU but i went down this path a month or 2 ago opened up my ECU and there is no eeprom that can be identified and all the parts have useless part number on them, it appears that i would need to connect up a daughter board if it is at all possible (and the daughter board would be expensive). So i stopped going down this route instead opting for looking at overriding control of the shift points with a manual switches which i am looking at at the moment. Also i plan to modify some inputs and outputs to the ECU to fool it into doing what i want.
Phantom that looks like its the correct transmission thanks for the link
I am only really looking at the final drive gear which i assume will change ratios gear settings. I think ill have to have a look at the mazda626 forums try my luck there thanks for the link
