Old 09-20-2010, 11:08 AM   #11 (permalink)
Have you considered a computer re-program being an auto and a Mazda there might be a tunre for it. While ECU tuners are used for tighter shifts and larger amouths of HP they can be used in the opposit for no Hp gains and better shifts. HP Tunners for example on the GMW J-Bodies can be used for this purpose it will alow your car to idle lower and shift more liek a standard car. Check the 626 forums if there is a tunner avalible for you car. And if anyone wants proof check out most program tunner websites.
2 cars one never gets driven the other is an MPG project already at 5% increase in standard driving economy CAI and Pulstar plus. Thinking weight reduction next year.
Old 09-20-2010, 11:55 AM   #12 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
Check out Mazda G4A-EL transmission - Wikipedia, the free encyclopedia that should be your trans it is also known as the Ford 4EAT-G.
For more info check out Mazda626.net Forums they should know if it is possible.
But yes it is possible to change the gearing on a FWD auto trans, on your car I'm not sure. On the gm 4t65-E there are several ones from 2.97 to 3.62 but that is only the final drive I do not know of anyone changing the individual gears.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
The Following User Says Thank You to Phantom For This Useful Post:
saand (09-20-2010)
Old 09-20-2010, 07:36 PM   #13 (permalink)
Wiki Writer
bugler - '91 Mazda 626
90 day: 35.89 mpg (US)
creeper, i would love to be able to tune the ECU but i went down this path a month or 2 ago opened up my ECU and there is no eeprom that can be identified and all the parts have useless part number on them, it appears that i would need to connect up a daughter board if it is at all possible (and the daughter board would be expensive). So i stopped going down this route instead opting for looking at overriding control of the shift points with a manual switches which i am looking at at the moment. Also i plan to modify some inputs and outputs to the ECU to fool it into doing what i want.
Phantom that looks like its the correct transmission thanks for the link
I am only really looking at the final drive gear which i assume will change ratios gear settings. I think ill have to have a look at the mazda626 forums try my luck there thanks for the link
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 05:11 PM
CVT vs. Manual vs. Automatic? Nate General Efficiency Discussion 12 05-04-2009 12:07 AM
Locking an automatic in a single gear? bennelson EcoModding Central 11 11-14-2008 01:03 PM
Hypermiling w/ an automatic tran? walkerjody Hypermiling / EcoDriver's Ed 11 10-03-2008 05:14 PM
Metro automatic trans mod. engineer93065 EcoModding Central 15 07-02-2008 01:01 AM
