Originally Posted by 96sentra
Wait, I don't understand how I would do a P&G with EOC
So I go to pulse to say 60mph, then I have to clutch, turn of the engine, and glide down to say 50mph
then reengage the clutch (which turns the engine back on), accelerate at full throttle (to minimize BSFC) to 60mph, then clutch and turn off the engine.
But that would kill my left leg with all that clutching. Is there a smarter way to P&G? I just don't understand how anyone actually does P&G in the real world (although the theory makes good sense)
How does Palemalenesian P&G?
Thanks
You can also just pull the thing out of gear without the clutch; use the gas pedal to ease the strain on the gear box then push it into neutral. WHen done right, it takes only the pressure of a single finger to push it out of gear, and doesn't harm the transaxle in any way.
Adding a fuel cut off switch to kill the fuel pump would be an easy mod and make it easier to kill the engine without using the key. Especially if your speedo is electronic controlled and dies without the key on, most modern cars are like this.
And as piwosalw said, your leg will get stronger
(BTW, don't start your glide phase if hills or traffic dictate it to be a bad idea.)
