Originally Posted by Wonderboy
Christ (pun intended), I've tried a few things like that. Stupid corner indicator lights vary, stupid front indicators vary btw civic HBs and even between 88-89 and 90-91 crxs. The shell of this car is an 88 HF, so I do have the light doors. The front end was ripped from a 91 Si, but the front indicators were gone by the time I got to it, so I either have to do something custom (probably) or find some lights that actually fit.
IIRC, most of the lights and such fit from 90-91 HB and CRX models, but certain things may be different, such as Si lights or certain things that are supposed to be "upgrades" from other models.
The other thing to pay attention to is that your headlights match the year of your fenders, else you'll need the corner lenses that match your headlight brackets. The difference between 88-89 and 90-91 corner lenses is whether or not the screws are showing. The fenders are stamped the same, IIRC, and you either have to add or remove a couple plastic nuts, depending on what combination you're using.
Sedan parts just don't work, FTMP. Forget 'em.
