Old 09-22-2010, 10:44 AM   #121 (permalink)
Dr. Jerryrigger
Dr. Jerryrigger's Avatar
The Sh*t-Box - '99 Subaru Impreza Outback Sport
90 day: 27.81 mpg (US)
I thought it was: rusty, 25% JB weld, and in need of consent adjustments (you must pick at lest two)
Thanks for the updates Brucey.
If you end up needing more belt surface I would think you could get away with using a second belt that uses the AC belt grooves in the CS pulley. This would be rather complicated if you wanted to still have AC, but could be a simpler/cheaper fix than putting new pulleys on all of your accessories.
Redneck Repair forum
