Old 10-05-2010, 12:45 AM   #2 (permalink)
mwebb
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
air flow too high
at 694 rpm air flow = 5.37 gm/s
too high - these have a MAF sensor ? i thought they were speed density ?
if speed density , intake vacuum is too low
if MAF it would be a digital MAF .
STFT = -8% and LTFT = 0%
whenever i see a vortech engine subtracting fuel , i think INJECTOR
those injector assemblies with the built in pressure regulators leak in to the manifold .... common failure , hard to prove without test equipment
can you get misfire counters ?
both current and history , if yes , display them at hot idle - i bet they will flag 1 or more cylinders
hi HC is always misfire or cat converter or both
hi nox , restricted EGR or some cylinders can be lean because the 02 sensor corrects for total fuel trim , if you are subtracting 8% , the system is correcting for 1 or 2 rich or misfiring cylinders and the rest of the cylinders are getting the same correction
so they are lean
bad cat also is suspect for hi nox but you need to resolve the subtracting fuel at idle thing first
what software are you using ?
