Old 10-12-2010, 01:18 AM   #24 (permalink)
abently
turquoise - '97 Toyota Starlet
90 day: 41.46 mpg (US)
Thought I would bump this topic with some real facts...
The main way you are going to be able to increase your water temperature fast, is firstly reduce the amount of water in the system (i.e. smaller radiator) and secondly switch to an electronic water pump.
If you just want to fool the ECU into deactivating cold-start enrichment, set-up a resistor in parallel, on the water temp sensor.
