Old 01-04-2010, 07:34 PM   #21 (permalink)
Little Blue - '98 Ford Escort ZX2 Cool
Team ZX2
90 day: 44.75 mpg (US)
Big Red - '00 Ford Excursion XLT
90 day: 15.53 mpg (US)
Have you read thru the adventures of COZX2 on gassavers? He did a loooot of EOC and ended up with a half blocked radiator for winter driving. Of course he had a steady commute, which it seems you don't have. In fact he stuffed his entire engine compartment with R30 bat's to help keep the heat in because EOC'ing he couldn't keep his temps up. I believe he would run the car up to temp and then start the EOC and if the temps got out of hand, he'd just turn on his rad fan (on a manual switch). He also had a block heater I really like mine.
Old 01-04-2010, 08:59 PM   #22 (permalink)
Mifunego's Avatar
The Taco - '99 Toyota Tacoma Prerunner
90 day: 19.29 mpg (US)
Ok, go easy on the new guy here - subfreezing temps notwithstanding, why is restricted cooling desirable, specifically pre-warmed intake air?
Old 01-04-2010, 09:02 PM   #23 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Search function. It's been covered in 100's of threads.
Look specifically for WAI, HAI, and grille block. The theory, benefits, and associated risks are brought up and discussed to no end all the time.
Also, check the 65+ Efficiency mods and the 100+ Hypermiling techniques links at the top of the page for tips and tricks, and better explanations of some of the normal subject material that comes up on this site.
Old 10-12-2010, 01:18 AM   #24 (permalink)
turquoise - '97 Toyota Starlet
90 day: 41.46 mpg (US)
Thought I would bump this topic with some real facts...
The main way you are going to be able to increase your water temperature fast, is firstly reduce the amount of water in the system (i.e. smaller radiator) and secondly switch to an electronic water pump.
If you just want to fool the ECU into deactivating cold-start enrichment, set-up a resistor in parallel, on the water temp sensor.
Old 01-13-2011, 09:41 PM   #25 (permalink)
Originally Posted by Old Mechanic View Post
Trust me on this one, 60,000 hours experience.
Start the engine cold with the radiator cap off.
You should see virtually no circulation until the thermostat opens.
If you see circulation before the stat opens the stat is bad.
Even with a properly working stat, you still have way too much heat loss through the radiator.
Completely block the radiator with a piece of cardboard. Carry a pair of scissors to trim the size of the cardboard if it actually gets to hot (I doubt it).
Use the block to get the operating temps up as high as you can (without being to hot), before you even mess with the thermostat.
As you get the operating temps up higher you can actually test it by placing your hand on the bottom radiator hose (the one the coolant comes out of the radiator through).
In summertime the bottom hose is usually around 110 degrees. In winter time it is much colder and that same much colder coolant goes into your engine and keeps it to cold.
The more the thermostat restricts the flow of coolant the colder the coolant going from the radiator back into the engine.
It could make a very significant difference in your mileage, especially based on your distance to temperature graph, which shows 5 miles before it even gets close to warm enough. The temp should actually be very close to the thermostat rating.
regards
Mech
Thanks for this advice! A couple of radiator blocks drop my idle iGPH within 5 minutes of driving from >.7 to <.3 in <32F weather, in comparison to >.7 to >.5. Since all of my trips these days are in the city and typically only a couple of miles long at a time, being able to reduce my idle GPH in such a short span of time is really helpful for my MPG, not to mention for my car heating. This is the single most significant mod I've made to my car beyond weight loss.
Killing a Diesel - a detailed how-to (much info on commonrail technology) Piwoslaw DIY / How-to 23 02-11-2011 03:21 PM
How much fuel does it take to re-start a warm engine? MetroMPG Hypermiling / EcoDriver's Ed 9 08-15-2009 02:31 PM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
DIY decel fuel cutoff; alternator regulation; auto start/stop MetroMPG EcoModding Central 0 11-29-2007 02:04 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
