Old 10-12-2010, 01:17 PM   #34 (permalink)
NeilBlanchard
Hi,
Originally Posted by dcb View Post
Please lets not call trains hybrids, even in quotes, they only have one power source, it will only further confuse people.
But, that is precisely what a diesel electric train is: a serial (or series) hybrid.
The Volt is a poorly implemented serial hybrid.
The ICE is way too big, and it is parts bin engineering. So, it weighs a lot more than it should. It is 1,000 pounds heavier than the Prius!
The ICE does not use the biggest advantage that it could: if it ran the ICE at a single, peak efficiency RPM and charged the battery, then it would avoid the biggest problem with convention ICE powertrains. The fact that you need a multi-ratio transmission means that the ICE by definition cannot be run at peak efficiency much of the time.
As GM *should* know, an EV is working with a lot less energy storage, and so it needs to be as efficient as possible. And a good serial hybrid is a good EV with an added genset that is *just* as big as it needs to be. Lotus, and Getrag and a third company I am forgetting the name of, have designed such gensets.
If GM had equaled the EV1 in aero drag, and improved on the weight with lighter lithium batteries (they probably had a 4 seat EV1 all set to go), then they would have had a home run on their hands.
As it stand, they have bunted a single.
