Old 10-12-2010, 12:20 PM   #31 (permalink)
The Geo - '93 Geo Metro
90 day: 45.16 mpg (US)
It's funny, I saw this pic:
And didn't even think "230" i thought "23 MPG"
Old 10-12-2010, 01:37 PM   #32 (permalink)
AJI
Rallye - '98 Peugeot 106 Rallye
90 day: 36.36 mpg (US)
RX-7 - '94 Mazda RX-7
90 day: 21.04 mpg (US)
NC - '09 Mazda MX-5
90 day: 32.68 mpg (US)
A lot of folks here might do well to read these articles:
It's typical media exaggeration, that's all it is.
The people complaining now that it's not a true EV were the ones complaining that it wasn't a full EV in the first place and were never going to buy the Volt.
For everyone else whose commute is under 40 miles it doesn't matter that there's connection between the gas engine and the wheels as they won't be using it anyway unless they do longer journeys, in which case the motor would switch on anyway, so it makes absolutely zero difference that it's powering the wheels directly rather than just charging a battery that's providing power to a motor for the wheels...
It's essentially a big media storm that's been blown out of all proportion.
The Following User Says Thank You to AJI For This Useful Post:
busypaws (10-12-2010)
Old 10-12-2010, 02:07 PM   #33 (permalink)
The first has its facts wrong. The second article admittedly chooses to ignore the lie.
Old 10-12-2010, 02:17 PM   #34 (permalink)
Hi,
Originally Posted by dcb View Post
Please lets not call trains hybrids, even in quotes, they only have one power source, it will only further confuse people.
But, that is precisely what a diesel electric train is: a serial (or series) hybrid.
The Volt is a poorly implemented serial hybrid.
The ICE is way too big, and it is parts bin engineering. So, it weighs a lot more than it should. It is 1,000 pounds heavier than the Prius!
The ICE does not use the biggest advantage that it could: if it ran the ICE at a single, peak efficiency RPM and charged the battery, then it would avoid the biggest problem with convention ICE powertrains. The fact that you need a multi-ratio transmission means that the ICE by definition cannot be run at peak efficiency much of the time.
As GM *should* know, an EV is working with a lot less energy storage, and so it needs to be as efficient as possible. And a good serial hybrid is a good EV with an added genset that is *just* as big as it needs to be. Lotus, and Getrag and a third company I am forgetting the name of, have designed such gensets.
If GM had equaled the EV1 in aero drag, and improved on the weight with lighter lithium batteries (they probably had a 4 seat EV1 all set to go), then they would have had a home run on their hands.
As it stand, they have bunted a single.
Old 10-12-2010, 03:53 PM   #35 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
I'm filing this comment under the "confused" category.
Hybrid vehicle - Wikipedia, the free encyclopedia
"A hybrid vehicle is a vehicle that uses two or more distinct power sources to move the vehicle."
Old 10-12-2010, 04:19 PM   #36 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
I couldn't agree more. In a locomotive, it's entirely appropriate to call the electric motor a transmission between the diesel engine and the wheels. And this is based on the fact there is only one power source, the DIESEL engine -- NO ELECTRIC STORAGE. They don't even regen on braking, they just dissipate the heat in resistor banks.
I'm not coasting, I'm shifting slowly.
Old 10-12-2010, 04:23 PM   #37 (permalink)
UFO
UFO's Avatar
Sounds like a tempest in a teapot to me.
Old 10-12-2010, 04:31 PM   #38 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Frank -
I should point out that the only aspects of this thing I'm defending are the parallel set-up and the plug-in Modus Operandi. Other than that, I personally have no interest in having one. Then again, I have no interest in having a Prius or Escape or Fusion hybrid either, just because hybrids don't offer palpable advantages to one with my particular transport situation. I do like and promote hybrids for those motorists that can benefit. That said, I like the idea of the Insight, although I have always lusted after CRX' and it's kinda similar; and owning an EV1 would be awesome but then again maybe just for the conversation piece value as it too wouldn't meet my needs. How about an EV1 with an ICE pusher trailer...
Yup. My POV is that the Volt is an implementation of the techy-home-brew plug-in Prius that already exists.
I won't buy one either. I consider the Volt to be a "flagship green car" with stuff that will hopefully filter down to regular ICE models.
CarloSW2
American Solar Energy Society
Old 10-12-2010, 04:34 PM   #39 (permalink)
I disagree... Its another American car company deception. I predict after the 10,000 or so GM plans to build are gone they'll quit producing them. The chevy volt is a 21'st century Edsel; not very good at what it does. Nissan will capture the all electric market. So we have Toyota and Nissan leading the way when all GM had to do was dust off and update the plans for the Impact (EV-1). Sigh.....
PS Ford is on the right track with this series hybrid:
Ford/Capstone 80 mpg 7 passenger vehicle
Old 10-12-2010, 04:40 PM   #40 (permalink)
AJI
NC - '09 Mazda MX-5
Go on then, I'll bite: Which facts are wrong in the first article?
As for the second article, there's no "ignoring" involved. It's common sense.
chevy volt, failure, hybrid
Restore oil additive... suspectnumber961 The Unicorn Corral 46 11-20-2018 01:15 AM
Hydrogen Generator Experiment willy57 DIY / How-to 601 08-23-2016 06:53 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-21-2012 12:34 AM
"Homebrew" Chevy Volt: Possible? ncc74656m EcoModding Central 24 10-14-2008 11:52 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 12:38 PM
