Thread: Gasifiers...
Old 10-12-2010, 04:14 PM   #9 (permalink)
bennelson
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
On a fuel-injected vehicle, all you would need to do is add a switch that turns the fuel injectors on and off.
You would pipe the synthesis gas into the air intake of the engine.
Simply turning the fuel injectors on or off would allow you to run the vehicle on either the wood gas OR gasoline.
Also, a number of alternative fuels are good at running a car, but not STARTING it. (For example, ethanol systems in cold climates.)
The hybrid system would make it easy to start the vehicle on gasoline, but run it on wood gas.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
