Old 10-15-2010, 05:20 PM   #200 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Nice! It's my favourite mod. I had a loose connection the other day which disabled it and it sucked. Can't go back now...
Apparently there is a workaround to avoid the mil light. You may have to trick the computer into thinking the solenoid is still there by removing it from the circuit but replacing it with a resistor that mimics the solenoid. Then wire up the solenoid directly to your switch. There is a way to do this with dual throw switches that allow it to be instantly reversible
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
