Old 10-15-2010, 08:24 PM   #37 (permalink)
Weather Spotter
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Originally Posted by Niner View Post
How comfortable are you with soldering?
If very, then I'd get the same little 5A blue relay and a board - the one I got was called a "dual mini board", it was about 3" x 1.5" and could be snapped in two. Each hole has a little copper around it but nothing is connected. You just stick the relay through the holes, solder from the backside, and then it's easy to solder stuff to it from there.
If not, I'd just get the 30A auto relay that they sell. It will probably work with that button.
I have a 30A auto relay, that was my" big one". I was going to hook that to the button but thecurrent of the relay is like 120mA. The switch can only do 50mA.
I can sodder relitivly well. If the board has rings then I. Should be good. I presum I can get that at the shack? Did you get some screw down terminals as well?
Thanks for all the help!
