What are the cylinder X stroke dimensions? With all that torque so low, it would need to be a very long stroke and very undersquare, as far as my limited knowledge goes? What is the redline of the engine?
Seems to be in here
Ford 300 Inline 6 Cylinder Specs, Ford 300 Engine Information, Firing Order : Engine Facts.com
I assume this is the banana (although they are all the same dimensions)
1987 - 1993 with Fuel Injection
Max Brake Horsepower - 145 @ 3400 rpm
Max Torque - 265 @ 2000 rpm
Stroke - 3.98
Bore - 4.0
Compression - 8.8
Firing Order - 153624
which suggests it is oversquare.
