Thread: rear diffuser
Old 04-16-2008, 03:01 PM   #13 (permalink)
RH77
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Originally Posted by Compaq888 View Post
It's Compaq...
it's suppose to curve...imagine blowing into a straw...
_____________
____________/ <-------straw A
_____________
_____________| <---- straw B
Now which one are you going to have an easier time blowing...A or B?
The answer is A...because B your air get concentrated and you have less space to work with...
A on the other hand flows more freely and exits more smoothly cause less drag...
Right, but I think what Fabrio means is that it abruptly curves upward, which can create turbulence. "Straw A" does not equate to your design:
Straw "C":
______________
____________J
It looks like it would need to be flush with the rear bumper as well -- the air goes upward and gets trapped.
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
