Old 10-19-2010, 03:01 AM   #1 (permalink)
slogfilet
VX Padawan
VX du Slog - '94 Honda Civic VX
Pizza pans for my VX
Picked up a few 14" pizza pans for the 13" wheels on my VX (somehow, it's a perfect fit... go figure.)
I was looking at different ways to mount them, and then thought to remove the center caps from my aftermarket wheels. They're held on by a single bolt, and I used that to attach the pans.
My main concern is that they are attached at only one point, which is slightly off-center. I can snug them down tight enough that I can't move them by hand. I also have some industrial strength Velcro I can add opposite the bolt to mitigate any rotational forces (the stuff is seriously strong.)
What do you guys think? I plan to test this at low speeds tomorrow, but do you think it definitely needs another attachment point?
These took all of 1 minute to install.
I added the nylon spacer so I could snug down the bolt without deforming the pan.
ID:	7148   Click image for larger version
ID:	7149   Click image for larger version
