Thread: Dual Intake
Old 04-16-2008, 08:58 PM   #12 (permalink)
RH77
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Originally Posted by tjts1 View Post
In extreme cold weather it helps warm up the engine faster. Most of these cars also use a hot wire air mass meter between the airbox and the throttle body. The sensor works by measuring the amount of electricity required to maintain a preset temperature on a heated wire in the air stream. It also uses a built in thermometer to reference the air temp. The air flap mechanism in the volvo airbox works to maintain a minimum 70f intake temp in order to make the AMM readings more accurate. The problem with the volvo device is that its controlled by a wax filled thermostat device that pushes against a spring. When the thermostat fails (usually after 5-10 years), the air flap goes into hot air only setting. In this situation the intake temp shoots up to 180-200f, slowly destroys the AMM and increases NOx emissions by a factor of 10 and drops fuel economy below 20mpg. Most volvo mechanics know to replace this $5 item but more often than not, these cars end up in the junkyard due to failed emissions test.
Great info.
That's a shame for a decent car: $5 or the junk heap. I'm sure the hot air created a fair share of detonation as well
The 'Teg has a wax plunger for the Fast Idle Thermo Valve. It's over 10 years old now -- good to know they tend to wear out, and what to look for.
One addition question -- do you know why the FE would drop so much? Does it "freak-out" into open-loop or cool the charge by running rich?
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
