Old 10-21-2010, 11:50 PM   #346 (permalink)
Nerys
Grrr :-)
Nerys's Avatar
Cherokee - '88 Jeep Cherokee
90 day: 19.44 mpg (US)
Ryo-Ohki - '94 Geo Metro Xfi
90 day: 50.15 mpg (US)
Vger 2 - '00 Plymouth Grand Voyager SE
Ninja - '89 Geo Tracker
90 day: 30.27 mpg (US)
so are you declaring that STOCK Pressure IE if the pump meets STOCK requirements for pressure that this is NOT ENOUGH ?
you keep ignoring that part of my statement.
Experimenting without reason is a recipe for disaster and losing a lot of money if I frak something up.
SO explain. first you say maybe your pressure is too low.
I say OK I will test it
then you say increase it anyway. regardless if its correct or not? yes or no?
if yes provide a valid REASON to force my fuel system to exceed factory settings.
we are talking about messing with something that could give me a really bad day here. I need more than "just do it"
it seems like you are just creating things to check trying to find the one thing I will resist checking and using that to bail?
So now its not "fix your car" now its ok its the fuel now ALTER YOUR CAR to compensate ???
